Commit e7c0b398 authored by Philip Carns's avatar Philip Carns
implement static_modulo algorithm
- not actually a consistent hash, but usable under the same API with
  trivial cpu and memory overhead for use cases that don't actually
  require the consistent hashing properties
parent 0b706ca0
...@@ -19,6 +19,7 @@ extern struct placement_mod_map multiring_mod_map; ...@@ -19,6 +19,7 @@ extern struct placement_mod_map multiring_mod_map;
extern struct placement_mod_map hash_lookup3_mod_map; extern struct placement_mod_map hash_lookup3_mod_map;
extern struct placement_mod_map hash_spooky_mod_map; extern struct placement_mod_map hash_spooky_mod_map;
extern struct placement_mod_map two_d_mod_map; extern struct placement_mod_map two_d_mod_map;
extern struct placement_mod_map static_modulo_mod_map;
/* table of available modules */ /* table of available modules */
static struct placement_mod_map *table[] = static struct placement_mod_map *table[] =
...@@ -29,6 +30,7 @@ static struct placement_mod_map *table[] = ...@@ -29,6 +30,7 @@ static struct placement_mod_map *table[] =
&hash_lookup3_mod_map, &hash_lookup3_mod_map,
&hash_spooky_mod_map, &hash_spooky_mod_map,
&two_d_mod_map, &two_d_mod_map,
&static_modulo_mod_map,
NULL, NULL,
...@@ -4,7 +4,8 @@ lib_libch_placement_la_SOURCES += \ ...@@ -4,7 +4,8 @@ lib_libch_placement_la_SOURCES += \
src/modules/placement-multiring.c \ src/modules/placement-multiring.c \
src/modules/placement-hash-lookup3.c \ src/modules/placement-hash-lookup3.c \
src/modules/placement-hash-spooky.c \ src/modules/placement-hash-spooky.c \
src/modules/placement-two-d.c src/modules/placement-two-d.c \
src/modules/placement-static-modulo.c
if CH_ENABLE_CRUSH if CH_ENABLE_CRUSH
lib_libch_placement_la_SOURCES += \ lib_libch_placement_la_SOURCES += \
* Copyright (C) 2013 University of Chicago.
* See COPYRIGHT notice in top-level directory.
/* NOTE NOTE NOTE NOTE
* this is *NOT* a consistent hash
* It uses an API compatible to the other modules in this library, but does
* not readily support adding or removing servers; the entire mapping would
* need to be recalculated on any change in server membership
#include <string.h>
#include <stdlib.h>
#include <assert.h>
#include "ch-placement.h"
#include "src/modules/placement-mod.h"
#include "src/lookup3.h"
static struct placement_mod* placement_mod_static_modulo(int n_svrs, int virt_factor, int seed);
static void placement_find_closest_static_modulo(struct placement_mod *mod, uint64_t obj, unsigned int replication,
unsigned long *server_idxs);
static void placement_finalize_static_modulo(struct placement_mod *mod);
struct placement_mod_map static_modulo_mod_map =
.type = "static_modulo",
.initiate = placement_mod_static_modulo,
struct static_modulo_state
unsigned int n_svrs;
struct placement_mod *mod_static_modulo;
struct static_modulo_state *mod_state;
/* NOTE: this placement algorithm will not benefit from virtual nodes;
* ignore that parameter
(void)virt_factor;
mod_static_modulo = malloc(sizeof(*mod_static_modulo));
if(!mod_static_modulo)
return(NULL);
mod_state = malloc(sizeof(*mod_state));
if(!mod_state)
free(mod_static_modulo);
return(NULL);
mod_static_modulo->data = mod_state;
mod_state->n_svrs = n_svrs;
mod_static_modulo->find_closest = placement_find_closest_static_modulo;
mod_static_modulo->create_striped = placement_create_striped_random;
mod_static_modulo->finalize = placement_finalize_static_modulo;
return(mod_static_modulo);
unsigned long* server_idxs)
struct static_modulo_state *mod_state = mod->data;
uint32_t h1 = 0;
uint32_t h2 = 0;
uint64_t hashed_obj;
int i;
/* hash incoming object id (this is like a pre conditioner so that we
* balance load even if id space is not well distributed)
ch_bj_hashlittle2(&obj, sizeof(obj), &h1, &h2);
hashed_obj = h1 + (((uint64_t)h2)<<32);
/* modulo to get first server, increment from there, with modulo to wrap
* around
server_idxs[0] = hashed_obj % mod_state->n_svrs;
for(i=1; i<replication; i++)
server_idxs[i] = (server_idxs[i-1] + 1) % mod_state->n_svrs;
return;
free(mod_state);
free(mod);
return;
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
* End:
* vim: ft=c ts=8 sts=4 sw=4 expandtab
Markdown is supported
0%
or
Please register or to comment
