Commit 8821caef authored by Philip Carns's avatar Philip Carns
Browse files
fix last reverse computation bug
parent 7474d5b3
...@@ -44,6 +44,7 @@ struct client_msg ...@@ -44,6 +44,7 @@ struct client_msg
struct codes_workload_op op_rc; struct codes_workload_op op_rc;
int target_barrier_count_rc; int target_barrier_count_rc;
int current_barrier_count_rc; int current_barrier_count_rc;
int released_barrier_count_rc;
static void handle_client_op_loop_rev_event( static void handle_client_op_loop_rev_event(
...@@ -200,8 +201,15 @@ static void handle_client_op_barrier_rev_event( ...@@ -200,8 +201,15 @@ static void handle_client_op_barrier_rev_event(
client_msg * m, client_msg * m,
tw_lp * lp) tw_lp * lp)
int i;
ns->current_barrier_count = m->current_barrier_count_rc; ns->current_barrier_count = m->current_barrier_count_rc;
ns->target_barrier_count = m->target_barrier_count_rc; ns->target_barrier_count = m->target_barrier_count_rc;
for(i=0; i<m->released_barrier_count_rc; i++)
codes_local_latency_reverse(lp);
return; return;
...@@ -247,6 +255,7 @@ static void handle_client_op_barrier_event( ...@@ -247,6 +255,7 @@ static void handle_client_op_barrier_event(
/* save barrier counters for reverse computation */ /* save barrier counters for reverse computation */
m->current_barrier_count_rc = ns->current_barrier_count; m->current_barrier_count_rc = ns->current_barrier_count;
m->target_barrier_count_rc = ns->target_barrier_count; m->target_barrier_count_rc = ns->target_barrier_count;
m->released_barrier_count_rc = 0;
assert(ns->target_barrier_count == 0 || ns->target_barrier_count == m->barrier_count); assert(ns->target_barrier_count == 0 || ns->target_barrier_count == m->barrier_count);
if(ns->target_barrier_count == 0) if(ns->target_barrier_count == 0)
...@@ -259,6 +268,7 @@ static void handle_client_op_barrier_event( ...@@ -259,6 +268,7 @@ static void handle_client_op_barrier_event(
if(ns->current_barrier_count == ns->target_barrier_count) if(ns->current_barrier_count == ns->target_barrier_count)
m->released_barrier_count_rc = ns->current_barrier_count;
/* release all clients, including self */ /* release all clients, including self */
for(i=0; i<ns->current_barrier_count; i++) for(i=0; i<ns->current_barrier_count; i++)
Markdown is supported
0% or .
Please register or to comment
