GitLab maintenance scheduled for Today, 2019-04-24, from 12:00 to 13:00 CDT - Services will be unavailable during this time.
Commit 54ce6320 authored by Swann Perarnau's avatar Swann Perarnau
[fix] allow perfwrapper for all commands
!27 caused the perfwrapper to only be activated for the command that
creates a container, and never for the other commands launched in an
already running container. This patch restore this feature.
parent 6aef1f9f
...@@ -102,13 +102,6 @@ class ContainerManager(object): ...@@ -102,13 +102,6 @@ class ContainerManager(object):
container_power['slowdown'] = None container_power['slowdown'] = None
container_power['manager'] = None container_power['manager'] = None
# It would've been better if argo-perf-wrapper wrapped around
# argo-nodeos-config and not the final command -- that way it would
# be running outside of the container. However, because
# argo-nodeos-config is suid root, perf can't monitor it.
if manifest.is_feature_enabled('perfwrapper'):
argv.append(self.perfwrapper)
if manifest.is_feature_enabled('power'): if manifest.is_feature_enabled('power'):
pp = manifest.app.isolators.power pp = manifest.app.isolators.power
if pp.profile in ["1", "True"]: if pp.profile in ["1", "True"]:
...@@ -143,6 +136,13 @@ class ContainerManager(object): ...@@ -143,6 +136,13 @@ class ContainerManager(object):
else: else:
environ['NRM_DAMPER'] = pp.damper environ['NRM_DAMPER'] = pp.damper
# Use hwloc-bind to launch each process in the conatiner by prepending # Use hwloc-bind to launch each process in the conatiner by prepending
# it as an argument to the command line, if enabled in manifest. # it as an argument to the command line, if enabled in manifest.
# The hardware binding computed using hwloc-distrib is used here # The hardware binding computed using hwloc-distrib is used here
Markdown is supported
0% or
Please register or to comment
