Commit d384712c authored by Swann Perarnau's avatar Swann Perarnau
Browse files
Merge branch 'wip/multi-node' into 'master'
[Feature] Multi- node and process support
Closes #17
See merge request !27
parents aece6b21 5a41baba
Pipeline #4156 passed with stages
in 53 seconds
...@@ -6,6 +6,7 @@ import logging ...@@ -6,6 +6,7 @@ import logging
import uuid import uuid
import signal import signal
import zmq import zmq
import os
logger = logging.getLogger('nrm-cmd') logger = logging.getLogger('nrm-cmd')
...@@ -60,12 +61,14 @@ class CommandLineInterface(object): ...@@ -60,12 +61,14 @@ class CommandLineInterface(object):
# build the command as a JSON dict containing enough info. We add to # build the command as a JSON dict containing enough info. We add to
# the command a container uuid as a way to make sure that we can make # the command a container uuid as a way to make sure that we can make
# the command idempotent. # the command idempotent.
containerid = str(uuid.uuid4()) environ = os.environ
command = {'command': 'run', command = {'clientid': self.uuid,
'ucontainername': argv.ucontainername,
'command': 'run',
'manifest': argv.manifest, 'manifest': argv.manifest,
'file': argv.command, 'file': argv.command,
'args': argv.args, 'args': argv.args,
'uuid': containerid, 'environ': dict(environ),
# command fsm # command fsm
state = 'init' state = 'init'
...@@ -76,7 +79,7 @@ class CommandLineInterface(object): ...@@ -76,7 +79,7 @@ class CommandLineInterface(object):
while(True): while(True):
msg = self.upstream_sub_socket.recv_json() msg = self.upstream_sub_socket.recv_json()
if isinstance(msg, dict) and msg.get('type') == 'container': if isinstance(msg, dict) and msg.get('type') == 'container':
if msg['uuid'] == containerid: if msg['clientid'] == self.uuid:
if msg['event'] == 'start': if msg['event'] == 'start':
if state == 'init': if state == 'init':
state = 'started' state = 'started'
...@@ -98,6 +101,17 @@ class CommandLineInterface(object): ...@@ -98,6 +101,17 @@ class CommandLineInterface(object):
exitmsg = msg exitmsg = msg
else: else:
logger.info("unexpected exit message: %r", msg) logger.info("unexpected exit message: %r", msg)
elif msg['event'] == 'process_start':
if state == 'init':
state = 'started'
logger.info("process started in existing "
"container: %r""", msg)
else:
logger.info("unexpected start message: %r", state)
exit(1)
elif msg['event'] == 'process_exit':
logger.info("process ended: %r", msg)
break
if outeof and erreof and state == 'exiting': if outeof and erreof and state == 'exiting':
state = 'exit' state = 'exit'
logger.info("container ended: %r", exitmsg) logger.info("container ended: %r", exitmsg)
...@@ -180,6 +194,9 @@ class CommandLineInterface(object): ...@@ -180,6 +194,9 @@ class CommandLineInterface(object):
parser_run.add_argument("command", help="command to execute") parser_run.add_argument("command", help="command to execute")
parser_run.add_argument("args", help="command arguments", parser_run.add_argument("args", help="command arguments",
nargs=argparse.REMAINDER) nargs=argparse.REMAINDER)
parser_run.add_argument("-u", "--ucontainername", help="""user-specified
name for container used to attach proceses""",
nargs='?', const=None, default=None)
parser_run.set_defaults(func=self.do_run) parser_run.set_defaults(func=self.do_run)
# kill container # kill container
...@@ -3,12 +3,12 @@ from __future__ import print_function ...@@ -3,12 +3,12 @@ from __future__ import print_function
from aci import ImageManifest from aci import ImageManifest
from collections import namedtuple from collections import namedtuple
import logging import logging
import os
from subprograms import ChrtClient, NodeOSClient, resources from subprograms import ChrtClient, NodeOSClient, resources
import uuid
logger = logging.getLogger('nrm') logger = logging.getLogger('nrm')
Container = namedtuple('Container', ['uuid', 'manifest', 'resources', Container = namedtuple('Container', ['uuid', 'manifest', 'resources',
'power', 'process']) 'power', 'processes', 'clientids'])
class ContainerManager(object): class ContainerManager(object):
...@@ -27,88 +27,127 @@ class ContainerManager(object): ...@@ -27,88 +27,127 @@ class ContainerManager(object):
"""Create a container according to the request. """Create a container according to the request.
Returns the pid of the container or a negative number for errors.""" Returns the pid of the container or a negative number for errors."""
container = None
container_name = None
containerexistsflag = False
processes = None
clientids = None
manifestfile = request['manifest'] manifestfile = request['manifest']
command = request['file'] command = request['file']
args = request['args'] args = request['args']
logger.info("run: manifest file: %s", manifestfile) environ = request['environ']
logger.info("run: command: %s", command) ucontainername = request['ucontainername']
logger.info("run: args: %r", args) logger.info("run: manifest file: %s", manifestfile)
logger.info("run: ucontainername: %s", ucontainername)
# TODO: Application library to load must be set during configuration
apppreloadlibrary = ''
manifest = ImageManifest() manifest = ImageManifest()
if not manifest.load(manifestfile): if not manifest.load(manifestfile):
logger.error("Manifest is invalid") logger.error("Manifest is invalid")
return None return None
# ask the resource manager for resources if hasattr(manifest.app.isolators, 'scheduler'):
req = resources(int(manifest.app.isolators.container.cpus.value), sched = manifest.app.isolators.scheduler
int(manifest.app.isolators.container.mems.value)) argv = self.chrt.getwrappedcmd(sched)
allocation = self.resourcemanager.schedule(request['uuid'], req) else:
logger.info("run: allocation: %r", allocation) argv = []
# Check if user-specified container exists else create it
if ucontainername in self.containers:
container_name = ucontainername
container = self.containers[ucontainername]
containerexistsflag = True
processes = container.processes
clientids = container.clientids
else:
processes = dict()
clientids = dict()
if ucontainername:
else:
# If no user-specified container name create one
container_name = str(uuid.uuid4())
alloc = self.resourcemanager.schedule(container_name, req)
logger.info("run: allocation: %r", alloc)
# create container
logger.info("creating container %s", container_name)
self.nodeos.create(container_name, alloc)
container_resources = dict()
container_resources['cpus'], container_resources['mems'] = alloc
# Container power settings
container_power = dict()
container_power['profile'] = None
container_power['policy'] = None
container_power['damper'] = None
container_power['slowdown'] = None
container_power['manager'] = None
# It would've been better if argo-perf-wrapper wrapped around
# argo-nodeos-config and not the final command -- that way it would
# be running outside of the container. However, because
# argo-nodeos-config is suid root, perf can't monitor it.
if hasattr(manifest.app.isolators, 'perfwrapper'):
manifest_perfwrapper = manifest.app.isolators.perfwrapper
if hasattr(manifest_perfwrapper, 'enabled'):
if manifest_perfwrapper.enabled in ["1", "True"]:
argv.append('argo-perf-wrapper')
if hasattr(manifest.app.isolators, 'power'):
if hasattr(manifest.app.isolators.power, 'enabled'):
pp = manifest.app.isolators.power
if pp.enabled in ["1", "True"]:
if pp.profile in ["1", "True"]:
container_power['profile'] = dict()
container_power['profile']['start'] = dict()
container_power['profile']['end'] = dict()
if pp.policy != "NONE":
container_power['policy'] = pp.policy
container_power['damper'] = pp.damper
container_power['slowdown'] = pp.slowdown
environ['LD_PRELOAD'] = apppreloadlibrary
# build context to execute # build context to execute
# environ['PATH'] = ("/usr/local/sbin:" # environ['PATH'] = ("/usr/local/sbin:"
# "/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin") # "/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin")
environ['ARGO_CONTAINER_UUID'] = container_name
environ['AC_APP_NAME'] = manifest.name environ['AC_APP_NAME'] = manifest.name
environ['AC_METADATA_URL'] = "localhost" environ['AC_METADATA_URL'] = "localhost"
logger.info("run: environ: %r", environ)
# create container argv.append(command)
container_name = request['uuid'] argv.extend(args)
self.nodeos.create(container_name, allocation)
container_resources['cpus'], container_resources['mems'] = allocation
applicationpreloadlibrary = ''
# run my command # run my command
if hasattr(manifest.app.isolators, 'scheduler'): process = self.nodeos.execute(container_name, argv, environ)
sched = manifest.app.isolators.scheduler processes[process.pid] = process
argv = self.chrt.getwrappedcmd(sched) clientids[process.pid] = request['clientid']
if containerexistsflag:
container.processes[process.pid] = process
self.pids[process.pid] = container
logger.info("Created process %s in container %s", process.pid,
container_name)
else: else:
argv = [] container = Container(container_name, manifest,
container_resources, container_power,
# It would've been better if argo-perf-wrapper wrapped around processes, clientids)
# argo-nodeos-config and not the final command -- that way it would self.pids[process.pid] = container
# be running outside of the container. However, because self.containers[container_name] = container
# argo-nodeos-config is suid root, perf can't monitor it. logger.info("Container %s created and running : %r",
if hasattr(manifest.app.isolators, 'perfwrapper'): container_name, container)
if hasattr(manifest.app.isolators.perfwrapper, 'enabled'):
if manifest.app.isolators.perfwrapper.enabled in ["1", "True"]:
environ['LD_PRELOAD'] = applicationpreloadlibrary
argv.append(command) return process.pid, container
argv.extend(args)
c = Container(container_name, manifest, container_resources,
container_power, process)
logger.info("Container %s created and running : %r", container_name, c)
return c
def delete(self, uuid): def delete(self, uuid):
"""Delete a container and kill all related processes.""" """Delete a container and kill all related processes."""
...@@ -116,7 +155,7 @@ class ContainerManager(object): ...@@ -116,7 +155,7 @@ class ContainerManager(object):
self.resourcemanager.update(uuid) self.resourcemanager.update(uuid)
c = self.containers[uuid] c = self.containers[uuid]
del self.containers[uuid] del self.containers[uuid]
del self.pids[c.process.pid] map(lambda i: self.pids.pop(c.processes[i].pid, None), c.processes)
def kill(self, uuid): def kill(self, uuid):
"""Kill all the processes of a container.""" """Kill all the processes of a container."""
...@@ -35,8 +35,8 @@ class Daemon(object): ...@@ -35,8 +35,8 @@ class Daemon(object):
logger.error("wrong message format: %r", msg) logger.error("wrong message format: %r", msg)
return return
if event == 'start': if event == 'start':
container_uuid = msg['container'] cid = msg['container']
container = self.container_manager.containers[container_uuid] container = self.container_manager.containers[cid]
self.application_manager.register(msg, container) self.application_manager.register(msg, container)
elif event == 'threads': elif event == 'threads':
uuid = msg['uuid'] uuid = msg['uuid']
...@@ -52,7 +52,7 @@ class Daemon(object): ...@@ -52,7 +52,7 @@ class Daemon(object):
if uuid in self.application_manager.applications: if uuid in self.application_manager.applications:
app = self.application_manager.applications[uuid] app = self.application_manager.applications[uuid]
c = self.container_manager.containers[app.container_uuid] c = self.container_manager.containers[app.cid]
if c.power['policy']: if c.power['policy']:
app.update_phase_context(msg) app.update_phase_context(msg)
elif event == 'exit': elif event == 'exit':
...@@ -79,38 +79,44 @@ class Daemon(object): ...@@ -79,38 +79,44 @@ class Daemon(object):
self.target = float(msg['limit']) self.target = float(msg['limit'])
logger.info("new target measure: %g", self.target) logger.info("new target measure: %g", self.target)
elif command == 'run': elif command == 'run':
container_uuid = msg['uuid'] logger.info("new container will be created if it doesn't "
if container_uuid in self.container_manager.containers: "exist: %r", msg)
logger.info("container already created: %r", pid, container = self.container_manager.create(msg)
container_uuid) cid = container.uuid
return clientid = container.clientids[pid]
logger.info("new container required: %r", msg)
if container.power['policy']:
container.power['manager'] = PowerPolicyManager(
container.resources['cpus'],
container.power['policy'],
float(container.power['damper']),
float(container.power['slowdown']))
if container.power['profile']:
p = container.power['profile']
p['start'] = self.machine_info['energy']['energy']
p['start']['time'] = self.machine_info['time']
# TODO: obviously we need to send more info than that # TODO: obviously we need to send more info than that
update = {'type': 'container', update = {'type': 'container',
'event': 'start', 'uuid': cid,
'uuid': container_uuid, 'clientid': clientid,
'errno': 0 if container else -1, 'errno': 0 if container else -1,
'pid': container.process.pid, 'pid': pid,
'power': container.power['policy']
self.upstream_pub.send_json(update)
if len(container.processes.keys()) == 1:
update['event'] = 'start'
update['power'] = container.power['policy']
else:
update['event'] = 'process_start'
# setup io callbacks # setup io callbacks
outcb = partial(self.do_children_io, container_uuid, 'stdout') outcb = partial(self.do_children_io, clientid, cid, 'stdout')
errcb = partial(self.do_children_io, container_uuid, 'stderr') errcb = partial(self.do_children_io, clientid, cid, 'stderr')
container.process.stdout.read_until_close(outcb, outcb) container.processes[pid].stdout.read_until_close(outcb, outcb)
container.process.stderr.read_until_close(errcb, errcb) container.processes[pid].stderr.read_until_close(errcb, errcb)
elif command == 'kill': elif command == 'kill':
logger.info("asked to kill container: %r", msg) logger.info("asked to kill container: %r", msg)
response = self.container_manager.kill(msg['uuid']) response = self.container_manager.kill(msg['uuid'])
...@@ -126,7 +132,7 @@ class Daemon(object): ...@@ -126,7 +132,7 @@ class Daemon(object):
else: else:
logger.error("invalid command: %r", command) logger.error("invalid command: %r", command)
def do_children_io(self, uuid, io, data): def do_children_io(self, clientid, uuid, io, data):
"""Receive data from one of the children, and send it down the pipe. """Receive data from one of the children, and send it down the pipe.
Meant to be partially defined on a children basis.""" Meant to be partially defined on a children basis."""
...@@ -134,6 +140,7 @@ class Daemon(object): ...@@ -134,6 +140,7 @@ class Daemon(object):
'event': io, 'event': io,
'uuid': uuid, 'uuid': uuid,
'payload': data or 'eof', 'payload': data or 'eof',
self.upstream_pub.send_json(update) self.upstream_pub.send_json(update)
...@@ -183,15 +190,21 @@ class Daemon(object): ...@@ -183,15 +190,21 @@ class Daemon(object):
# check if this is an exit # check if this is an exit
if os.WIFEXITED(status) or os.WIFSIGNALED(status): if os.WIFEXITED(status) or os.WIFSIGNALED(status):
container = self.container_manager.pids[pid] container = self.container_manager.pids[pid]
pp = container.power clientid = container.clientids[pid]
if pp['policy']: remaining_pids = [p for p in container.processes.keys()
pp['manager'].reset_all() if p != pid]
msg = {'type': 'container', msg = {'type': 'container',
'event': 'exit',
'status': status, 'status': status,
'uuid': container.uuid, 'uuid': container.uuid,
if pp['profile']:
if not remaining_pids:
msg['event'] = 'exit'
if pp['policy']:
if pp['profile']:
e = pp['profile']['end'] e = pp['profile']['end']
self.machine_info = self.sensor_manager.do_update() self.machine_info = self.sensor_manager.do_update()
e = self.machine_info['energy']['energy'] e = self.machine_info['energy']['energy']
...@@ -205,7 +218,15 @@ class Daemon(object): ...@@ -205,7 +218,15 @@ class Daemon(object):
logger.info("Container %r profile data: %r", logger.info("Container %r profile data: %r",
container.uuid, diff) container.uuid, diff)
msg['profile_data'] = diff msg['profile_data'] = diff
self.container_manager.delete(container.uuid) self.container_manager.delete(container.uuid)
else:
msg['event'] = 'process_exit'
# Remove the pid of process that is finished
container.processes.pop(pid, None)
self.container_manager.pids.pop(pid, None)
logger.info("Process %s in Container %s has finised.",
pid, container.uuid)
self.upstream_pub.send_json(msg) self.upstream_pub.send_json(msg)
else: else:
logger.debug("child update ignored") logger.debug("child update ignored")
Markdown is supported
0% or .
Please register or to comment
