Commit 402a2524 authored by Sridutt Bhalachandra's avatar Sridutt Bhalachandra
[feature] Support for Process/Task pinning
Added support for pinning process/task to a core. This is important for
allowing the use of power policies that use contextual information from an
application phase and use it for computing frequency levels for the next phase.
In absence of process/task pinning, the contextual information obtained does
not serve any value as it is not representative of application phase behavior
on a core as the processes and task can migrate during the next phase.
See Issue #20
parent 442d31f6
...@@ -14,14 +14,14 @@ ...@@ -14,14 +14,14 @@
"name": "argo/container", "name": "argo/container",
"value": { "value": {
"cpus": "4", "cpus": "24",
"mems": "1" "mems": "2"
"name": "argo/perfwrapper", "name": "argo/perfwrapper",
"enabled": "1" "enabled": "0"
...@@ -30,9 +30,15 @@ ...@@ -30,9 +30,15 @@
"enabled": "1", "enabled": "1",
"profile": "1", "profile": "1",
"policy": "NONE", "policy": "NONE",
"damper": "0.1", "damper": "1000000000",
"slowdown": "1.1" "slowdown": "1.1"
"name": "argo/hwbind",
"value": {
"enabled": "1"
...@@ -202,6 +202,29 @@ class Power(SpecField): ...@@ -202,6 +202,29 @@ class Power(SpecField):
return True return True
class HwBind(SpecField):
"""Hardware bindings for a container."""
fields = {"enabled": spec(unicode, False),
def __init__(self):
"""Create empty hardware bindings settings object."""
pass
def load(self, data):
"""Load hardware bindings settings."""
ret = super(HwBind, self).load(data)
if not ret:
return ret
if self.enabled not in ["0", "False", "1", "True"]:
logger.error("Invalid value for hardware bindings enabled: %s",
self.enabled)
return False
return True
class IsolatorList(SpecField): class IsolatorList(SpecField):
"""Represent the list of isolator in a Manifest.""" """Represent the list of isolator in a Manifest."""
...@@ -210,6 +233,7 @@ class IsolatorList(SpecField): ...@@ -210,6 +233,7 @@ class IsolatorList(SpecField):
"argo/container": spec(Container, True), "argo/container": spec(Container, True),
"argo/perfwrapper": spec(PerfWrapper, False), "argo/perfwrapper": spec(PerfWrapper, False),
"argo/power": spec(Power, False), "argo/power": spec(Power, False),
"argo/hwbind": spec(HwBind, False),
def __init__(self): def __init__(self):
...@@ -4,10 +4,12 @@ from aci import ImageManifest ...@@ -4,10 +4,12 @@ from aci import ImageManifest
from collections import namedtuple from collections import namedtuple
import logging import logging
from subprograms import ChrtClient, NodeOSClient, resources from subprograms import ChrtClient, NodeOSClient, resources
import operator
logger = logging.getLogger('nrm') logger = logging.getLogger('nrm')
Container = namedtuple('Container', ['uuid', 'manifest', 'resources', Container = namedtuple('Container', ['uuid', 'manifest', 'resources',
'power', 'processes', 'clientids']) 'power', 'processes', 'clientids',
'hwbindings'])
class ContainerManager(object): class ContainerManager(object):
...@@ -26,6 +28,8 @@ class ContainerManager(object): ...@@ -26,6 +28,8 @@ class ContainerManager(object):
self.containers = dict() self.containers = dict()
self.pids = dict() self.pids = dict()
self.resourcemanager = rm self.resourcemanager = rm
self.hwloc = rm.hwloc
self.nodeos = NodeOSClient()
self.chrt = ChrtClient() self.chrt = ChrtClient()
self.pmpi_lib = pmpi_lib self.pmpi_lib = pmpi_lib
...@@ -38,6 +42,8 @@ class ContainerManager(object): ...@@ -38,6 +42,8 @@ class ContainerManager(object):
processes = None processes = None
clientids = None clientids = None
pp = None pp = None
hwbindings = None
bind_index = 0
manifestfile = request['manifest'] manifestfile = request['manifest']
command = request['file'] command = request['file']
...@@ -69,13 +75,17 @@ class ContainerManager(object): ...@@ -69,13 +75,17 @@ class ContainerManager(object):
containerexistsflag = True containerexistsflag = True
processes = container.processes processes = container.processes
clientids = container.clientids clientids = container.clientids
hwbindings = container.hwbindings
bind_index = len(processes)
else: else:
processes = dict() processes = dict()
clientids = dict() clientids = dict()
hwbindings = dict()
# ask the resource manager for resources # ask the resource manager for resources
req = resources(int(manifest.app.isolators.container.cpus.value), ncpus = int(manifest.app.isolators.container.cpus.value)
int(manifest.app.isolators.container.mems.value)) nmems = int(manifest.app.isolators.container.mems.value)
req = resources(ncpus, nmems)
alloc = self.resourcemanager.schedule(container_name, req) alloc = self.resourcemanager.schedule(container_name, req)
logger.info("run: allocation: %r", alloc) logger.info("run: allocation: %r", alloc)
...@@ -116,6 +126,16 @@ class ContainerManager(object): ...@@ -116,6 +126,16 @@ class ContainerManager(object):
container_power['damper'] = pp.damper container_power['damper'] = pp.damper
container_power['slowdown'] = pp.slowdown container_power['slowdown'] = pp.slowdown
# Compute hardware bindings
if hasattr(manifest.app.isolators, 'hwbind'):
manifest_hwbind = manifest.app.isolators.hwbind
if hasattr(manifest_hwbind, 'enabled'):
if manifest_hwbind.enabled in ["1", "True"]:
hwbindings['enabled'] = True
hwbindings['distrib'] = sorted(self.hwloc.distrib(
ncpus, alloc), key=operator.
attrgetter('cpus'))
# build context to execute # build context to execute
# environ['PATH'] = ("/usr/local/sbin:" # environ['PATH'] = ("/usr/local/sbin:"
# "/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin") # "/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin")
...@@ -132,6 +152,17 @@ class ContainerManager(object): ...@@ -132,6 +152,17 @@ class ContainerManager(object):
else: else:
environ['NRM_DAMPER'] = pp.damper environ['NRM_DAMPER'] = pp.damper
# Use hwloc-bind to launch each process in the conatiner by prepending
# it as an argument to the command line, if enabled in manifest.
# The hardware binding computed using hwloc-distrib is used here
# --single
if bool(hwbindings) and hwbindings['enabled']:
argv.append('hwloc-bind')
# argv.append('--single')
argv.append('core:'+str(hwbindings['distrib'][bind_index].cpus[0]))
argv.append('--membind')
argv.append('numa:'+str(hwbindings['distrib'][bind_index].mems[0]))
argv.append(command) argv.append(command)
argv.extend(args) argv.extend(args)
...@@ -148,7 +179,7 @@ class ContainerManager(object): ...@@ -148,7 +179,7 @@ class ContainerManager(object):
else: else:
container = Container(container_name, manifest, container = Container(container_name, manifest,
container_resources, container_power, container_resources, container_power,
processes, clientids) processes, clientids, hwbindings)
self.pids[process.pid] = container self.pids[process.pid] = container
self.containers[container_name] = container self.containers[container_name] = container
logger.info("Container %s created and running : %r", logger.info("Container %s created and running : %r",
...@@ -32,7 +32,7 @@ def list2bitmask(l): ...@@ -32,7 +32,7 @@ def list2bitmask(l):
"""Convert a list into a bitmask.""" """Convert a list into a bitmask."""
m = 0 m = 0
for e in l: for e in l:
m |= 1 << e m |= 1 << int(e)
return hex(m) return hex(m)
Markdown is supported
0%
or
Please register or to comment
