Skip to content
GitLab
Menu
Projects
Groups
Snippets
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
argo
argonix
Commits
221e2f59
Commit
221e2f59
authored
Feb 21, 2019
by
Valentin Reis
Browse files
verbosity management.
parent
23781aae
Pipeline
#5480
passed with stage
in 27 seconds
Changes
1
Pipelines
1
Hide whitespace changes
Inline
Side-by-side
src/Argonix.hs
View file @
221e2f59
@@ -227,8 +227,8 @@ cleanSocket = sudoRemoveFile printWarning "socket"
setupSystem
ArgsCommon
Shell
setupSystem
ArgsCommon
Shell
setupSystem
sa
do
setupSystem
sa
do
printInfo
"Setting the nix-build environment up."
doVerbose
printInfo
printInfo
"Cleaning sockets."
doVerbose
printInfo
"Cleaning sockets."
Prelude
mapM_
Prelude
mapM_
cleanSocket
cleanSocket
"/tmp/nrm-downstream-in"
@@ -236,16 +236,16 @@ setupSystem sa = do
"/tmp/nrm-upstream-in"
"/tmp/nrm-upstream-event"
printInfo
"Setting up a cache directory:"
doVerbose
printInfo
cachedir
single
cachedir
single
inproc
"mktemp"
"-d"
"/tmp/deletable-nix-cache-XXXX"
empty
inproc
"mktemp"
"-d"
empty
export
"XDG_CACHE_HOME"
lineToText
cachedir
export
"XDG_CACHE_HOME"
lineToText
cachedir
printInfo
lineToText
cachedir
" exported to XDG_CACHE_HOME"
doVerbose
printInfo
lineToText
cachedir
printInfo
"running nix-build for the containers attribute."
doVerbose
printInfo
printCommand
"nix-build "
pack
unwords
nixArguments
"containers"
sa
doVerbose
printCommand
"nix-build "
pack
unwords
nixArguments
"containers"
sa
nodeos_config
single
nodeos_config
single
inproc
"nix-build"
fmap
pack
nixArguments
"containers"
sa
empty
inproc
"nix-build"
fmap
pack
nixArguments
"containers"
sa
empty
printInfo
"Checking filesystem attributes on /tmp"
doVerbose
printInfo
checkFsAttributes
"/tmp"
checkFsAttributes
"/tmp"
vshell
"sudo rm -rf /tmp/argo_nodeos_config"
empty
vshell
empty
vshell
vshell
@@ -262,7 +262,9 @@ setupSystem sa = do
ExitFailure
n
die
"Setting suid bit failed with exit code "
repr
n
ExitFailure
n
die
repr
n
vshell
"sudo /tmp/argo_nodeos_config --clean_config=kill_content:true"
empty
vshell
empty
void
printInfo
"Done setting the environment for nix-build up."
void
printInfo
where
vshell
verboseShell
verbosity
sa
Verbose
where
vshell
verboseShell
verbose
verbose
verbosity
sa
Verbose
doVerbose
when
verbose
nixArguments
String
ArgsCommon
String
nixArguments
String
ArgsCommon
String
nixArguments
target
ArgsCommon
nixArguments
target
ArgsCommon
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
