Commit 4074c4c6 authored by Axel Kohlmeyer's avatar Axel Kohlmeyer
Browse files
correct some more broken or outdated links
parent a1098d57
...@@ -80,8 +80,8 @@ per-timestep CPU cost, FFTs are only a portion of long-range ...@@ -80,8 +80,8 @@ per-timestep CPU cost, FFTs are only a portion of long-range
Coulombics, and 1d FFTs are only a portion of the FFT cost (parallel Coulombics, and 1d FFTs are only a portion of the FFT cost (parallel
communication can be costly). A breakdown of these timings is printed communication can be costly). A breakdown of these timings is printed
to the screen at the end of a run using the "kspace_style to the screen at the end of a run using the "kspace_style
pppm"_kspace_style.html command. The "Run output"_doc page gives more pppm"_kspace_style.html command. The "Run output"_Run_output.html
details. doc page gives more details.
FFTW is a fast, portable FFT library that should also work on any FFTW is a fast, portable FFT library that should also work on any
platform and can be faster than the KISS FFT library. You can platform and can be faster than the KISS FFT library. You can
...@@ -1582,8 +1582,6 @@ molecular visualization and analysis program, to enable LAMMPS to dump ...@@ -1582,8 +1582,6 @@ molecular visualization and analysis program, to enable LAMMPS to dump
snapshots in formats compatible with various molecular simulation snapshots in formats compatible with various molecular simulation
tools. tools.
:link(vmd_home,http://www.ks.uiuc.edu/Research/vmd)
To use this package you must have the desired VMD plugins available on To use this package you must have the desired VMD plugins available on
your system. your system.
...@@ -1635,6 +1633,7 @@ tools: ...@@ -1635,6 +1633,7 @@ tools:
"AtomEye"_atomeye (the libAtoms version of AtomEye contains a NetCDF reader not present in the standard distribution) :ul "AtomEye"_atomeye (the libAtoms version of AtomEye contains a NetCDF reader not present in the standard distribution) :ul
:link(ovito,http://www.ovito.org) :link(ovito,http://www.ovito.org)
:link(vmd_home,https://www.ks.uiuc.edu/Research/vmd/)
:link(atomeye,http://www.libatoms.org) :link(atomeye,http://www.libatoms.org)
[Author:] Lars Pastewka (Karlsruhe Institute of Technology). [Author:] Lars Pastewka (Karlsruhe Institute of Technology).
...@@ -1998,3 +1997,5 @@ src/USER-VTK: filenames -> commands ...@@ -1998,3 +1997,5 @@ src/USER-VTK: filenames -> commands
src/USER-VTK/README src/USER-VTK/README
lib/vtk/README lib/vtk/README
"dump vtk"_dump_vtk.html :ul "dump vtk"_dump_vtk.html :ul
...@@ -58,7 +58,7 @@ Package, Description, Doc page, Example, Library ...@@ -58,7 +58,7 @@ Package, Description, Doc page, Example, Library
"USER-MGPT"_Packages_details.html#PKG-USER-MGPT, fast MGPT multi-ion potentials, "pair_style mgpt"_pair_mgpt.html, USER/mgpt, no "USER-MGPT"_Packages_details.html#PKG-USER-MGPT, fast MGPT multi-ion potentials, "pair_style mgpt"_pair_mgpt.html, USER/mgpt, no
"USER-MISC"_Packages_details.html#PKG-USER-MISC, single-file contributions, USER-MISC/README, USER/misc, no "USER-MISC"_Packages_details.html#PKG-USER-MISC, single-file contributions, USER-MISC/README, USER/misc, no
"USER-MOFFF"_Packages_details.html#PKG-USER-MOFFF, styles for "MOF-FF"_MOFplus force field, "pair_style buck6d/coul/gauss"_pair_buck6d_coul_gauss.html, USER/mofff, no "USER-MOFFF"_Packages_details.html#PKG-USER-MOFFF, styles for "MOF-FF"_MOFplus force field, "pair_style buck6d/coul/gauss"_pair_buck6d_coul_gauss.html, USER/mofff, no
"USER-MOLFILE"_Packages_details.html#PKG-USER-MOLFILE, "VMD"_vmd_home molfile plug-ins,"dump molfile"_dump_molfile.html, n/a, ext "USER-MOLFILE"_Packages_details.html#PKG-USER-MOLFILE, "VMD"_https://www.ks.uiuc.edu/Research/vmd/ molfile plug-ins,"dump molfile"_dump_molfile.html, n/a, ext
"USER-NETCDF"_Packages_details.html#PKG-USER-NETCDF, dump output via NetCDF,"dump netcdf"_dump_netcdf.html, n/a, ext "USER-NETCDF"_Packages_details.html#PKG-USER-NETCDF, dump output via NetCDF,"dump netcdf"_dump_netcdf.html, n/a, ext
"USER-OMP"_Packages_details.html#PKG-USER-OMP, OpenMP-enabled styles,"Speed omp"_Speed_omp.html, "Benchmarks"_http://lammps.sandia.gov/bench.html, no "USER-OMP"_Packages_details.html#PKG-USER-OMP, OpenMP-enabled styles,"Speed omp"_Speed_omp.html, "Benchmarks"_http://lammps.sandia.gov/bench.html, no
"USER-PHONON"_Packages_details.html#PKG-USER-PHONON, phonon dynamical matrix,"fix phonon"_fix_phonon.html, USER/phonon, no "USER-PHONON"_Packages_details.html#PKG-USER-PHONON, phonon dynamical matrix,"fix phonon"_fix_phonon.html, USER/phonon, no
Markdown is supported
0% or .
Please register or to comment
