Skip to content
GitLab
Menu
Projects
Groups
Snippets
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
Menu
Open sidebar
AIG-public
Cobalt
Commits
9dba3670
Commit
9dba3670
authored
Nov 18, 2016
by
Paul Rich
Browse files
Merge branch 'develop' into 37-ssh-interactive-mode
Conflicts: src/lib/Components/system/CraySystem.py
parents
7e8e9790
db7bb983
Changes
5
Hide whitespace changes
Inline
Side-by-side
misc/cobalt.init.cray
View file @
9dba3670
@@ -49,14 +49,8 @@ start_component () {
then
then
date
/bin/date
date
/bin/date
if
$component
"alps_script_forker"
echo
$date
: START
component
/var/log/cobalt/
component
_
HOSTNAME
.out
then
nohup
DAEMONDIR
component
.py"
$component_args
--config-files
CONFIGFILE
/var/log/cobalt/
component
_
HOSTNAME
.out 2>&1 &
echo
$date
: START
component
/var/log/cobalt/
component
_
HOSTNAME
.out
nohup
DAEMONDIR
component
.py"
$component_args
--config-files
CONFIGFILE
/var/log/cobalt/
component
_
HOSTNAME
.out 2>&1 &
else
echo
$date
: START
component
/var/log/cobalt/
component
.out
nohup
DAEMONDIR
component
.py"
$component_args
--config-files
CONFIGFILE
/var/log/cobalt/
component
.out 2>&1 &
fi
echo
"done"
echo
"done"
return
0
return
0
src/lib/Components/base.py
View file @
9dba3670
@@ -278,6 +278,8 @@ class Component (object):
self
_component_lock
threading
Lock
self
_component_lock
threading
Lock
self
_component_lock_acquired_time
None
self
None
self
statistics
Statistics
self
statistics
Statistics
self
logger
info
"%s:%s component executing on %s"
self
name
self
implementation
socket
gethostname
def
__getstate__
self
def
__getstate__
self
state
state
@@ -296,6 +298,8 @@ class Component (object):
self
_component_lock
threading
Lock
self
_component_lock
threading
Lock
self
None
self
None
self
statistics
Statistics
self
statistics
Statistics
self
logger
info
self
name
self
implementation
socket
gethostname
def
self
def
self
entry_time
time
time
entry_time
time
time
src/lib/Components/system/ALPSProcessGroup.py
View file @
9dba3670
@@ -55,6 +55,5 @@ class ALPSProcessGroup(ProcessGroup):
if
self
mode
'interactive'
if
self
mode
'interactive'
if
len
USER_SESSION_HOSTS
if
len
USER_SESSION_HOSTS
pass
return
super
ALPSProcessGroup
self
start
return
super
ALPSProcessGroup
self
start
View file @
9dba3670
@@ -15,9 +15,16 @@ from Cobalt.Components.base import Component, exposed, automatic, query, locking
from
Cobalt.Components.system.base_system
import
BaseSystem
from
import
BaseSystem
from
Cobalt.Components.system.CrayNode
import
CrayNode
from
import
CrayNode
from
Cobalt.Components.system.base_pg_manager
import
ProcessGroupManager
from
import
ProcessGroupManager
from
Cobalt.Components.system.ALPSProcessGroup
import
ALPSProcessGroup
from
Cobalt.Exceptions
import
ComponentLookupError
from
Cobalt.Exceptions
import
from
Cobalt.Exceptions
import
JobNotInteractive
from
Cobalt.Exceptions
import
JobNotInteractive
Updated
upstream
from
import
ALPSProcessGroup
from
import
ALPSProcessGroup
from
Cobalt.Exceptions
import
JobValidationError
from
Cobalt.DataTypes.ProcessGroup
import
ProcessGroup
from
Cobalt.Exceptions
import
JobValidationError
Stashed
changes
from
Cobalt.Util
import
compact_num_list
expand_num_list
from
Cobalt.Util
import
compact_num_list
expand_num_list
from
Cobalt.Util
import
init_cobalt_config
get_config_option
from
Cobalt.Util
import
init_cobalt_config
get_config_option
@@ -25,6 +32,7 @@ _logger = logging.getLogger(__name__)
init_cobalt_config
init_cobalt_config
SYSTEM_SIZE
int
get_config_option
'system'
'size'
UPDATE_THREAD_TIMEOUT
int
get_config_option
'alpssystem'
int
get_config_option
'alpssystem'
'update_thread_timeout'
10
10
TEMP_RESERVATION_TIME
int
get_config_option
'alpssystem'
int
get_config_option
'alpssystem'
@@ -39,10 +47,13 @@ CLEANUP_DRAIN_WINDOW = get_config_option('system', 'cleanup_drain_window', 300)
#Epsilon for backfilling. This system does not do this on a per-node basis.
BACKFILL_EPSILON
int
get_config_option
'system'
'backfill_epsilon'
120
BACKFILL_EPSILON
int
get_config_option
'system'
'backfill_epsilon'
120
ELOGIN_HOSTS
host
for
host
in
split
get_config_option
'alpssystem'
'elogin_hosts'
DRAIN_MODES
'first-fit'
'backfill'
DRAIN_MODES
'first-fit'
'backfill'
CLEANING_ID
1
CLEANING_ID
1
def
chain_loc_list
loc_list
def
chain_loc_list
loc_list
'''Take a list of compact Cray locations,
expand and concatenate them.
@@ -1228,15 +1239,36 @@ class CraySystem(BaseSystem):
#Right now this does nothing. Still figuring out what a valid
#specification looks like.
# mode on this system defaults to script.
mode
spec
get
'mode'
None
if
mode
is
None
or
mode
False
spec
'mode'
'script'
if
spec
'mode'
not
in
'script'
'interactive'
raise
JobValidationError
"Mode %s is not supported on Cray systems."
mode
# FIXME: Pull this out of the system configuration from ALPS ultimately.
# For now, set this from config for the PE count per node
# nodes
= int(spec['node
s
spec
'nodecount'
int
spec
'node
count
# proccount = spec.get('proccount', None)
# if proccount is None:
# nodes *
# nodes *
spec
'proccount'
spec
'nodecount'
if
spec
'proccount'
SYSTEM_SIZE
raise
JobValidationError
'Job requested %s nodes. Maximum permitted size is %s'
spec
'proccount'
SYSTEM_SIZE
spec
'proccount'
spec
'nodecount'
#set multiplier for default depth
mode
spec
get
'mode'
'script'
spec
'mode'
mode
if
mode
'interactive'
# Handle which script host should handle their job if they're on a
# login.
if
spec
get
'qsub_host'
None
in
ELOGIN_HOSTS
spec
'ssh_host'
self
_get_ssh_host
return
spec
return
spec
def
_get_ssh_host
self
return
None
exposed
exposed
def
verify_locations
self
nodes
def
verify_locations
self
nodes
'''verify that a list of nodes exist on this system. Return the list
tools/build-cdbwriter-ddl/cobalt-db-update2-ddl.src
View file @
9dba3670
@@ -46,15 +46,15 @@ alter table "##COBALT_SCHEMA##"."RESERVATION_DATA"
add BLOCK_PASSTHROUGH INTEGER;
-- DDL Statements for table "##COBALT_SCHEMA##"."RESERVATION_
DATA
EVENTS
update
table
"##COBALT_SCHEMA##"."RESERVATION_EVENTS"
update "##COBALT_SCHEMA##"."RESERVATION_EVENTS"
SET NAME =
terminating
SET NAME =
terminating
where NAME =
ending
where NAME =
ending
insert into "##COBALT_SCHEMA##"."RESERVATION_EVENTS" values
(default,
deferred
(default,
deferred
(default,
deactivating
(default,
deactivating
(default,
released
(default,
released
(default,
instance_end
(default,
instance_end
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
