Commit adc8fe15 authored by Noah Wolfe's avatar Noah Wolfe
Browse files
Cleaned slimfly comments
parent 588210f2
...@@ -1180,43 +1180,6 @@ static void slimfly_packet_event_rc(tw_lp *sender) ...@@ -1180,43 +1180,6 @@ static void slimfly_packet_event_rc(tw_lp *sender)
return; return;
/* given two group IDs, find the router of the src_gid that connects to the dest_gid*/
tw_lpid slim_getRouterFromGroupID(int dest_gid,
int src_gid,
int num_routers,
int total_groups)
#if USE_DIRECT_SCHEME
int dest = dest_gid;
if(dest == total_groups - 1) {
dest = src_gid;
return src_gid * num_routers + (dest % num_routers);
#else
int group_begin = src_gid * num_routers;
int group_end = (src_gid * num_routers) + num_routers-1;
int offset = (dest_gid * num_routers - group_begin) / num_routers;
if((dest_gid * num_routers) < group_begin)
offset = (group_begin - dest_gid * num_routers) / num_routers; // take absolute value
int half_channel = num_routers / 4;
int index = (offset - 1)/(half_channel * num_routers);
offset=(offset - 1) % (half_channel * num_routers);
// If the destination router is in the same group
tw_lpid router_id;
if(index % 2 != 0)
router_id = group_end - (offset / half_channel); // start from the end
else
router_id = group_begin + (offset / half_channel);
return router_id;
#endif
/*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/ /*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/
void slim_router_credit_send(router_state * s, tw_bf * bf, slim_terminal_message * msg, tw_lp * lp, int sq) void slim_router_credit_send(router_state * s, tw_bf * bf, slim_terminal_message * msg, tw_lp * lp, int sq)
...@@ -1604,29 +1567,6 @@ void slim_packet_arrive_rc(terminal_state * s, tw_bf * bf, slim_terminal_message ...@@ -1604,29 +1567,6 @@ void slim_packet_arrive_rc(terminal_state * s, tw_bf * bf, slim_terminal_message
slimfly_total_time -= (tw_now(lp) - msg->travel_start_time); slimfly_total_time -= (tw_now(lp) - msg->travel_start_time);
s->total_time = msg->saved_avg_time; s->total_time = msg->saved_avg_time;
/*if(msg->chunk_id == num_chunks - 1)
mn_stats* stat;
stat = model_net_find_stats(msg->category, s->slimfly_stats_array);
stat->recv_count--;
stat->recv_bytes -= msg->packet_size;
stat->recv_time -= tw_now(lp) - msg->travel_start_time;
N_finished_packets--;
if(bf->c3)
slimfly_max_latency = msg->saved_available_time;
if (msg->chunk_id == num_chunks-1 &&
msg->remote_event_size_bytes &&
msg->is_pull)
int net_id = model_net_get_id(LP_METHOD_NM);
model_net_event_rc(net_id, lp, msg->pull_size);
struct qhash_head * hash_link = NULL; struct qhash_head * hash_link = NULL;
struct sfly_qhash_entry * tmp = NULL; struct sfly_qhash_entry * tmp = NULL;
...@@ -1783,47 +1723,6 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1783,47 +1723,6 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message *
#endif #endif
/*tw_event * e;
slim_terminal_message * m;
if(msg->chunk_id == num_chunks-1)
bf->c2 = 1;
mn_stats* stat = model_net_find_stats(msg->category, s->slimfly_stats_array);
stat->recv_count++;
stat->recv_bytes += msg->packet_size;
stat->recv_time += tw_now(lp) - msg->travel_start_time;
N_finished_packets++;
total_hops -= msg->my_N_hop;
slimfly_total_time += tw_now( lp ) - msg->travel_start_time;
if (slimfly_max_latency < tw_now( lp ) - msg->travel_start_time)
bf->c3 = 1;
msg->saved_available_time = slimfly_max_latency;
slimfly_max_latency=tw_now( lp ) - msg->travel_start_time;
if(msg->remote_event_size_bytes)
void * tmp_ptr = model_net_method_get_edata(SLIMFLY, msg);
ts = g_tw_lookahead + 0.1 + (1/s->params->cn_bandwidth) * msg->remote_event_size_bytes;
if (msg->is_pull){
struct codes_mctx mc_dst =
codes_mctx_set_global_direct(msg->sender_mn_lp);
struct codes_mctx mc_src =
codes_mctx_set_global_direct(lp->gid);
model_net_event_mctx(net_id, &mc_src, &mc_dst, msg->category,
msg->sender_lp, msg->pull_size, ts,
msg->remote_event_size_bytes, tmp_ptr, 0, NULL, lp);
else {
e = tw_event_new(msg->final_dest_gid, ts, lp);
m = tw_event_data(e);
memcpy(m, tmp_ptr, msg->remote_event_size_bytes);
tw_event_send(e);
/* Now retreieve the number of chunks completed from the hash and update /* Now retreieve the number of chunks completed from the hash and update
* them */ * them */
void *m_data_src = model_net_method_get_edata(SLIMFLY, msg); void *m_data_src = model_net_method_get_edata(SLIMFLY, msg);
Markdown is supported
0% or .
Please register or to comment
