Commit a92a8506 authored by Nikhil's avatar Nikhil
Sensible defaults
Change-Id: I4740549495b8a5eac920dc9f7f0419aadeb2a84a
parent f3d64593
...@@ -214,7 +214,7 @@ static void base_read_config(const char * anno, model_net_base_params *p){ ...@@ -214,7 +214,7 @@ static void base_read_config(const char * anno, model_net_base_params *p){
"setting to %lf\n", p->nic_seq_delay); "setting to %lf\n", p->nic_seq_delay);
p->node_copy_queues = 4; p->node_copy_queues = 1;
ret = configuration_get_value_int(&config, "PARAMS", "node_copy_queues", anno, ret = configuration_get_value_int(&config, "PARAMS", "node_copy_queues", anno,
&p->node_copy_queues); &p->node_copy_queues);
if(ret && !g_tw_mynode) { if(ret && !g_tw_mynode) {
...@@ -57,7 +57,7 @@ tw_stime mn_msg_offset = 0.0; ...@@ -57,7 +57,7 @@ tw_stime mn_msg_offset = 0.0;
static int is_msg_params_set[MAX_MN_MSG_PARAM_TYPES]; static int is_msg_params_set[MAX_MN_MSG_PARAM_TYPES];
static mn_sched_params sched_params; // MN_MSG_PARAM_SCHED static mn_sched_params sched_params; // MN_MSG_PARAM_SCHED
static tw_stime start_time_param; // MN_MSG_PARAM_START_TIME static tw_stime start_time_param; // MN_MSG_PARAM_START_TIME
static double cn_bandwidth = 10; static double cn_bandwidth = 20;
tw_stime codes_cn_delay; tw_stime codes_cn_delay;
static int codes_node_eager_limit = 16000; static int codes_node_eager_limit = 16000;
Markdown is supported
0%
or
Please register or to comment
