Commit 51f2f821 authored by Noah Wolfe's avatar Noah Wolfe
Browse files
Slimfly updates/fixes to match dragonfly
 - Updated from copy function to rc_stack
 - Minor updates to chunk hash tracking
 - Removed bitfield from get_output_port(), credit_send() and
do_adaptive_routing() functions
 - Bug fix for saving output port and channel in router_packet_send
forward and reverse event handlers
parent ea0e9d76
...@@ -266,6 +266,7 @@ struct router_state ...@@ -266,6 +266,7 @@ struct router_state
slim_terminal_message_list ***queued_msgs; slim_terminal_message_list ***queued_msgs;
slim_terminal_message_list ***queued_msgs_tail; slim_terminal_message_list ***queued_msgs_tail;
int *in_send_loop; int *in_send_loop;
struct rc_stack * st;
tw_stime* last_buf_full; tw_stime* last_buf_full;
tw_stime* busy_time; tw_stime* busy_time;
...@@ -299,7 +300,7 @@ static int slimfly_rank_hash_compare( ...@@ -299,7 +300,7 @@ static int slimfly_rank_hash_compare(
void *key, struct qhash_head *link) void *key, struct qhash_head *link)
struct sfly_hash_key *message_key = (struct sfly_hash_key *)key; struct sfly_hash_key *message_key = (struct sfly_hash_key *)key;
struct sfly_qhash_entry *tmp; struct sfly_qhash_entry *tmp = NULL;
tmp = qhash_entry(link, struct sfly_qhash_entry, hash_link); tmp = qhash_entry(link, struct sfly_qhash_entry, hash_link);
...@@ -316,7 +317,7 @@ static int slimfly_hash_func(void *k, int table_size) ...@@ -316,7 +317,7 @@ static int slimfly_hash_func(void *k, int table_size)
key = key * 21; key = key * 21;
key = ~key ^ (tmp->sender_id >> 4); key = ~key ^ (tmp->sender_id >> 4);
key = key * tmp->sender_id; key = key * tmp->sender_id;
return (int)(key % table_size); return (int)(key & (table_size - 1));
/* convert GiB/s and bytes to ns */ /* convert GiB/s and bytes to ns */
...@@ -340,12 +341,14 @@ static int slimfly_get_msg_sz(void) ...@@ -340,12 +341,14 @@ static int slimfly_get_msg_sz(void)
return sizeof(slim_terminal_message); return sizeof(slim_terminal_message);
/*static void free_tmp(void * ptr) static void free_tmp(void * ptr)
struct sfly_qhash_entry * sfly = ptr; struct sfly_qhash_entry * sfly = ptr;
free(sfly->remote_event_data); if(sfly->remote_event_data)
free(sfly); free(sfly->remote_event_data);
}*/ if(sfly)
free(sfly);
static void append_to_terminal_message_list( static void append_to_terminal_message_list(
slim_terminal_message_list ** thisq, slim_terminal_message_list ** thisq,
...@@ -375,23 +378,6 @@ static void prepend_to_terminal_message_list( ...@@ -375,23 +378,6 @@ static void prepend_to_terminal_message_list(
thisq[index] = msg; thisq[index] = msg;
static void create_prepend_to_terminal_message_list(
slim_terminal_message_list ** thistail,
int index,
slim_terminal_message *msg) {
slim_terminal_message_list* new_entry = (slim_terminal_message_list*)malloc(
sizeof(slim_terminal_message_list));
slim_init_terminal_message_list(new_entry, msg);
if(msg->remote_event_size_bytes) {
void *m_data = model_net_method_get_edata(SLIMFLY, msg);
size_t s = msg->remote_event_size_bytes + msg->local_event_size_bytes;
new_entry->event_data = (void*)malloc(s);
memcpy(new_entry->event_data, m_data, s);
prepend_to_terminal_message_list( thisq, thistail, index, new_entry);
static slim_terminal_message_list* return_head( static slim_terminal_message_list* return_head(
slim_terminal_message_list ** thistail, slim_terminal_message_list ** thistail,
...@@ -414,6 +400,7 @@ static slim_terminal_message_list* return_tail( ...@@ -414,6 +400,7 @@ static slim_terminal_message_list* return_tail(
int index) { int index) {
slim_terminal_message_list *tail = thistail[index]; slim_terminal_message_list *tail = thistail[index];
assert(tail);
if(tail->prev != NULL) { if(tail->prev != NULL) {
tail->prev->next = NULL; tail->prev->next = NULL;
thistail[index] = tail->prev; thistail[index] = tail->prev;
...@@ -425,50 +412,6 @@ static slim_terminal_message_list* return_tail( ...@@ -425,50 +412,6 @@ static slim_terminal_message_list* return_tail(
return tail; return tail;
static void copy_terminal_list_entry( slim_terminal_message_list *cur_entry,
slim_terminal_message *cur_msg = &cur_entry->msg;
msg->travel_start_time = cur_msg->travel_start_time;
msg->packet_ID = cur_msg->packet_ID;
strcpy(msg->category, cur_msg->category);
msg->final_dest_gid = cur_msg->final_dest_gid;
msg->msg_start_time = msg->msg_start_time;
msg->sender_lp = cur_msg->sender_lp;
msg->dest_terminal_id = cur_msg->dest_terminal_id;
msg->src_terminal_id = cur_msg->src_terminal_id;
msg->local_id = cur_msg->local_id;
msg->origin_router_id = cur_msg->origin_router_id;
msg->my_N_hop = cur_msg->my_N_hop;
msg->my_l_hop = cur_msg->my_l_hop;
msg->my_g_hop = cur_msg->my_g_hop;
msg->intm_lp_id = cur_msg->intm_lp_id;
msg->saved_channel = cur_msg->saved_channel;
msg->saved_vc = cur_msg->saved_vc;
msg->last_hop = cur_msg->last_hop;
msg->path_type = cur_msg->path_type;
msg->vc_index = cur_msg->vc_index;
msg->output_chan = cur_msg->output_chan;
msg->is_pull = cur_msg->is_pull;
msg->pull_size = cur_msg->pull_size;
msg->intm_group_id = cur_msg->intm_group_id;
msg->intm_router_id = cur_msg->intm_router_id;
msg->chunk_id = cur_msg->chunk_id;
msg->sender_mn_lp = cur_msg->sender_mn_lp;
msg->total_size = cur_msg->total_size;
msg->packet_size = cur_msg->packet_size;
msg->message_id = cur_msg->message_id;
msg->local_event_size_bytes = cur_msg->local_event_size_bytes;
msg->remote_event_size_bytes = cur_msg->remote_event_size_bytes;
msg->sender_node = cur_msg->sender_node;
msg->next_stop = cur_msg->next_stop;
msg->magic = cur_msg->magic;
if(msg->local_event_size_bytes + msg->remote_event_size_bytes > 0) {
memcpy(m_data, cur_entry->event_data,
msg->local_event_size_bytes + msg->remote_event_size_bytes);
static void slimfly_read_config(const char * anno, slimfly_param *params){ static void slimfly_read_config(const char * anno, slimfly_param *params){
// shorthand // shorthand
slimfly_param *p = params; slimfly_param *p = params;
...@@ -920,6 +863,8 @@ void slim_router_setup(router_state * r, tw_lp * lp) ...@@ -920,6 +863,8 @@ void slim_router_setup(router_state * r, tw_lp * lp)
r->last_buf_full = (tw_stime*)malloc(p->radix * sizeof(tw_stime)); r->last_buf_full = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
r->busy_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime)); r->busy_time = (tw_stime*)malloc(p->radix * sizeof(tw_stime));
rc_stack_create(&r->st);
for(int i=0; i < p->radix; i++) for(int i=0; i < p->radix; i++)
// Set credit & router occupancy // Set credit & router occupancy
...@@ -1181,10 +1126,8 @@ static void slimfly_packet_event_rc(tw_lp *sender) ...@@ -1181,10 +1126,8 @@ static void slimfly_packet_event_rc(tw_lp *sender)
/*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/ /*When a packet is sent from the current router and a buffer slot becomes available, a credit is sent back to schedule another packet event*/
void slim_router_credit_send(router_state * s, tw_bf * bf, slim_terminal_message * msg, tw_lp * lp, int sq) void slim_router_credit_send(router_state * s, slim_terminal_message * msg, tw_lp * lp, int sq)
(void)bf;
tw_event * buf_e; tw_event * buf_e;
tw_stime ts; tw_stime ts;
slim_terminal_message * buf_msg; slim_terminal_message * buf_msg;
...@@ -1388,8 +1331,10 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1388,8 +1331,10 @@ void slim_packet_send_rc(terminal_state * s, tw_bf * bf, slim_terminal_message *
s->packet_counter--; s->packet_counter--;
s->vc_occupancy[0] -= s->params->chunk_size; s->vc_occupancy[0] -= s->params->chunk_size;
create_prepend_to_terminal_message_list(s->terminal_msgs, slim_terminal_message_list* cur_entry = rc_stack_pop(s->st);
s->terminal_msgs_tail, 0, msg);
s->terminal_msgs_tail, 0, cur_entry);
if(bf->c3) { if(bf->c3) {
tw_rand_reverse_unif(lp->rng); tw_rand_reverse_unif(lp->rng);
...@@ -1509,8 +1454,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms ...@@ -1509,8 +1454,7 @@ void slim_packet_send(terminal_state * s, tw_bf * bf, slim_terminal_message * ms
vc_occupancy_storage_terminal[s->terminal_id][0][index] = s->vc_occupancy[0]/s->params->chunk_size; vc_occupancy_storage_terminal[s->terminal_id][0][index] = s->vc_occupancy[0]/s->params->chunk_size;
#endif #endif
cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0); cur_entry = return_head(s->terminal_msgs, s->terminal_msgs_tail, 0);
copy_terminal_list_entry(cur_entry, msg); rc_stack_push(lp, cur_entry, slim_delete_terminal_message_list, s->st);
slim_delete_terminal_message_list(cur_entry);
s->terminal_length -= s->params->chunk_size; s->terminal_length -= s->params->chunk_size;
cur_entry = s->terminal_msgs[0]; cur_entry = s->terminal_msgs[0];
...@@ -1601,13 +1545,12 @@ void slim_packet_arrive_rc(terminal_state * s, tw_bf * bf, slim_terminal_message ...@@ -1601,13 +1545,12 @@ void slim_packet_arrive_rc(terminal_state * s, tw_bf * bf, slim_terminal_message
N_finished_msgs--; N_finished_msgs--;
s->total_msg_size -= msg->total_size; s->total_msg_size -= msg->total_size;
// struct sfly_qhash_entry * d_entry_pop = (struct sfly_qhash_entry*)rc_stack_pop(s->st); struct sfly_qhash_entry * d_entry_pop = rc_stack_pop(s->st);
struct sfly_qhash_entry * d_entry_pop = msg->saved_hash;
qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link)); qhash_add(s->rank_tbl, &key, &(d_entry_pop->hash_link));
s->rank_tbl_pop++; s->rank_tbl_pop++;
hash_link = qhash_search(s->rank_tbl, &key); hash_link = &(d_entry_pop->hash_link);
tmp = qhash_entry(hash_link, struct sfly_qhash_entry, hash_link); tmp = d_entry_pop;
if(bf->c4) if(bf->c4)
...@@ -1676,9 +1619,6 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1676,9 +1619,6 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message *
tw_stime ts = g_tw_lookahead + s->params->credit_delay + tw_rand_unif(lp->rng); tw_stime ts = g_tw_lookahead + s->params->credit_delay + tw_rand_unif(lp->rng);
if(msg->packet_ID == TRACK)
printf("\n terminal sending credit at chan %d \n", msg->saved_vc);
// no method_event here - message going to router // no method_event here - message going to router
...@@ -1802,8 +1742,7 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message * ...@@ -1802,8 +1742,7 @@ void slim_packet_arrive(terminal_state * s, tw_bf * bf, slim_terminal_message *
/* Remove the hash entry */ /* Remove the hash entry */
qhash_del(hash_link); qhash_del(hash_link);
msg->saved_hash = tmp; rc_stack_push(lp, tmp, free_tmp, s->st);
//rc_stack_push(lp, tmp, free_tmp, s->st);
s->rank_tbl_pop--; s->rank_tbl_pop--;
#if TERMINAL_SENDS_RECVS_LOG #if TERMINAL_SENDS_RECVS_LOG
...@@ -1866,7 +1805,7 @@ void slim_terminal_event( terminal_state * s, ...@@ -1866,7 +1805,7 @@ void slim_terminal_event( terminal_state * s,
*(int *)bf = (int)0; *(int *)bf = (int)0;
assert(msg->magic == slim_terminal_magic_num); assert(msg->magic == slim_terminal_magic_num);
//rc_stack_gc(lp, s->st); rc_stack_gc(lp, s->st);
switch(msg->type) switch(msg->type)
case T_GENERATE: case T_GENERATE:
...@@ -2658,12 +2597,10 @@ tw_lpid slim_get_next_stop(router_state * s, ...@@ -2658,12 +2597,10 @@ tw_lpid slim_get_next_stop(router_state * s,
/* gets the output port corresponding to the next stop of the message */ /* gets the output port corresponding to the next stop of the message */
int slim_get_output_port( router_state * s, int slim_get_output_port( router_state * s,
tw_bf * bf,
slim_terminal_message * msg, slim_terminal_message * msg,
tw_lp * lp, tw_lp * lp,
int next_stop ) int next_stop )
(void)bf;
(void)lp; (void)lp;
int output_port = -1, terminal_id; int output_port = -1, terminal_id;
...@@ -2711,7 +2648,6 @@ int slim_get_output_port( router_state * s, ...@@ -2711,7 +2648,6 @@ int slim_get_output_port( router_state * s,
/* UGAL (first condition is from booksim), output port equality check comes from Dally slimfly'09*/ /* UGAL (first condition is from booksim), output port equality check comes from Dally slimfly'09*/
static int do_adaptive_routing( router_state * s, static int do_adaptive_routing( router_state * s,
tw_bf * bf,
int dest_router_id, int dest_router_id,
...@@ -2731,7 +2667,7 @@ static int do_adaptive_routing( router_state * s, ...@@ -2731,7 +2667,7 @@ static int do_adaptive_routing( router_state * s,
//Compute the next stop on the minimal path and get port number //Compute the next stop on the minimal path and get port number
int temp_minimal_next_stop = getMinimalRouterFromEquations(msg, dest_router_id, s); int temp_minimal_next_stop = getMinimalRouterFromEquations(msg, dest_router_id, s);
codes_mapping_get_lp_id(lp_group_name, "slimfly_router", s->anno, 0, temp_minimal_next_stop, 0, &minimal_next_stop); codes_mapping_get_lp_id(lp_group_name, "slimfly_router", s->anno, 0, temp_minimal_next_stop, 0, &minimal_next_stop);
minimal_out_port = slim_get_output_port(s, bf, msg, lp, minimal_next_stop); minimal_out_port = slim_get_output_port(s, msg, lp, minimal_next_stop);
//Compute the next stop on the non-minimal paths and get port number //Compute the next stop on the non-minimal paths and get port number
int temp_nonmin_next_stop; int temp_nonmin_next_stop;
...@@ -2739,7 +2675,7 @@ static int do_adaptive_routing( router_state * s, ...@@ -2739,7 +2675,7 @@ static int do_adaptive_routing( router_state * s,
temp_nonmin_next_stop = getMinimalRouterFromEquations(msg, intm_id[i], s); temp_nonmin_next_stop = getMinimalRouterFromEquations(msg, intm_id[i], s);
codes_mapping_get_lp_id(lp_group_name, "slimfly_router", s->anno, 0, temp_nonmin_next_stop, 0, &nonmin_next_stop[i]); codes_mapping_get_lp_id(lp_group_name, "slimfly_router", s->anno, 0, temp_nonmin_next_stop, 0, &nonmin_next_stop[i]);
nonmin_out_port[i] = slim_get_output_port(s, bf, msg, lp, nonmin_next_stop[i]); nonmin_out_port[i] = slim_get_output_port(s, msg, lp, nonmin_next_stop[i]);
//Only computed on first hop so vc will always be 0 for both min and nonmin //Only computed on first hop so vc will always be 0 for both min and nonmin
...@@ -2826,8 +2762,9 @@ void slim_router_packet_receive_rc(router_state * s, ...@@ -2826,8 +2762,9 @@ void slim_router_packet_receive_rc(router_state * s,
if(bf->c2) { if(bf->c2) {
slim_delete_terminal_message_list(return_tail(s->pending_msgs[output_port], slim_terminal_message_list * tail = return_tail(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan)); s->pending_msgs_tail[output_port], output_chan);
slim_delete_terminal_message_list(tail);
s->vc_occupancy[output_port][output_chan] -= s->params->chunk_size; s->vc_occupancy[output_port][output_chan] -= s->params->chunk_size;
codes_local_latency_reverse(lp); codes_local_latency_reverse(lp);
...@@ -2908,7 +2845,7 @@ slim_router_packet_receive( router_state * s, ...@@ -2908,7 +2845,7 @@ slim_router_packet_receive( router_state * s,
if(msg->last_hop == TERMINAL && routing == ADAPTIVE) if(msg->last_hop == TERMINAL && routing == ADAPTIVE)
next_stop = do_adaptive_routing(s, bf, &(cur_chunk->msg), lp, dest_router_id, intm_router); next_stop = do_adaptive_routing(s, &(cur_chunk->msg), lp, dest_router_id, intm_router);
else else
...@@ -2929,7 +2866,8 @@ slim_router_packet_receive( router_state * s, ...@@ -2929,7 +2866,8 @@ slim_router_packet_receive( router_state * s,
&mapping_type_id, NULL, &mapping_rep_id, &mapping_offset); &mapping_type_id, NULL, &mapping_rep_id, &mapping_offset);
int local_router_id = (mapping_offset + mapping_rep_id); int local_router_id = (mapping_offset + mapping_rep_id);
output_port = slim_get_output_port(s, bf, msg, lp, next_stop); output_port = slim_get_output_port(s, &(cur_chunk->msg), lp, next_stop);
assert(output_port >= 0);
output_chan = 0; output_chan = 0;
int max_vc_size = s->params->cn_vc_size; int max_vc_size = s->params->cn_vc_size;
...@@ -2947,15 +2885,15 @@ slim_router_packet_receive( router_state * s, ...@@ -2947,15 +2885,15 @@ slim_router_packet_receive( router_state * s,
max_vc_size = s->params->local_vc_size; max_vc_size = s->params->local_vc_size;
output_chan = msg->my_N_hop; output_chan = msg->my_N_hop;
if(msg->my_N_hop >3) // if(msg->my_N_hop >3)
output_chan = 3; // output_chan = 3;
else if(output_port < (s->params->num_local_channels + s->params->num_global_channels)) else if(output_port < (s->params->num_local_channels + s->params->num_global_channels))
max_vc_size = s->params->global_vc_size; max_vc_size = s->params->global_vc_size;
#if TRACK_OUTPUT #if TRACK_OUTPUT
...@@ -2980,7 +2918,7 @@ slim_router_packet_receive( router_state * s, ...@@ -2980,7 +2918,7 @@ slim_router_packet_receive( router_state * s,
#endif #endif
bf->c2 = 1; bf->c2 = 1;
slim_router_credit_send(s, bf, msg, lp, -1); slim_router_credit_send(s, msg, lp, -1);
append_to_terminal_message_list( s->pending_msgs[output_port], s->pending_msgs_tail[output_port], output_chan, cur_chunk); append_to_terminal_message_list( s->pending_msgs[output_port], s->pending_msgs_tail[output_port], output_chan, cur_chunk);
s->vc_occupancy[output_port][output_chan] += s->params->chunk_size; s->vc_occupancy[output_port][output_chan] += s->params->chunk_size;
...@@ -3033,18 +2971,20 @@ void slim_router_packet_send_rc(router_state * s, ...@@ -3033,18 +2971,20 @@ void slim_router_packet_send_rc(router_state * s,
tw_bf * bf, tw_bf * bf,
slim_terminal_message * msg, tw_lp * lp) slim_terminal_message * msg, tw_lp * lp)
int output_port = msg->vc_index; int output_port = msg->saved_vc;
int output_chan = msg->output_chan; int output_chan = msg->saved_channel;
if(bf->c1) { if(bf->c1) {
s->in_send_loop[output_port] = 1; s->in_send_loop[output_port] = 1;
return; return;
slim_terminal_message_list * cur_entry = rc_stack_pop(s->st);
assert(cur_entry);
if(bf->c11) if(bf->c11)
s->link_traffic[output_port] -= msg->packet_size % s->params->chunk_size; s->link_traffic[output_port] -= cur_entry->msg.packet_size % s->params->chunk_size;
if(bf->c12) if(bf->c12)
...@@ -3052,8 +2992,8 @@ void slim_router_packet_send_rc(router_state * s, ...@@ -3052,8 +2992,8 @@ void slim_router_packet_send_rc(router_state * s,
s->next_output_available_time[output_port] = msg->saved_available_time; s->next_output_available_time[output_port] = msg->saved_available_time;
create_prepend_to_terminal_message_list(s->pending_msgs[output_port], prepend_to_terminal_message_list(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan, msg); s->pending_msgs_tail[output_port], output_chan, cur_entry);
...@@ -3092,6 +3032,8 @@ slim_router_packet_send( router_state * s, ...@@ -3092,6 +3032,8 @@ slim_router_packet_send( router_state * s,
msg->saved_vc = output_port;
msg->saved_channel = output_chan;
if(cur_entry == NULL) if(cur_entry == NULL)
...@@ -3195,8 +3137,7 @@ slim_router_packet_send( router_state * s, ...@@ -3195,8 +3137,7 @@ slim_router_packet_send( router_state * s,
cur_entry = return_head(s->pending_msgs[output_port], cur_entry = return_head(s->pending_msgs[output_port],
s->pending_msgs_tail[output_port], output_chan); s->pending_msgs_tail[output_port], output_chan);
cur_entry = s->pending_msgs[output_port][3]; cur_entry = s->pending_msgs[output_port][3];
...@@ -3289,7 +3230,7 @@ void slim_router_buf_update(router_state * s, tw_bf * bf, slim_terminal_message ...@@ -3289,7 +3230,7 @@ void slim_router_buf_update(router_state * s, tw_bf * bf, slim_terminal_message
bf->c1 = 1; bf->c1 = 1;
slim_terminal_message_list *head = return_head(s->queued_msgs[indx], slim_terminal_message_list *head = return_head(s->queued_msgs[indx],
s->queued_msgs_tail[indx], output_chan); s->queued_msgs_tail[indx], output_chan);
slim_router_credit_send(s, bf, &head->msg, lp, 1); slim_router_credit_send(s, &head->msg, lp, 1);
append_to_terminal_message_list(s->pending_msgs[indx], append_to_terminal_message_list(s->pending_msgs[indx],
s->pending_msgs_tail[indx], output_chan, head); s->pending_msgs_tail[indx], output_chan, head);
s->vc_occupancy[indx][output_chan] -= s->params->chunk_size; s->vc_occupancy[indx][output_chan] -= s->params->chunk_size;
Markdown is supported
0% or .
Please register or to comment
