As a reminder, there are two types of event tracing the full event trace (`ev_trace_f`) or only events that trigger rollbacks (`rbev_trace_f`).
It's set up so that you can have different functions for both types of event tracing, or you can use the same function for both.
Immediately after each function pointer is a `size_t` type that takes the amount of data that the function will be placing in the buffer,
so ROSS can appropriately handle things.
If you have multiple LPs, you can do a `st_trace_type` for each LP, or you can reuse. *Note*: You can only reuse `st_trace_type` and the event type collection
function for LPs that use the same type of message struct. For example, the dragonfly terminal and router LPs both use the `terminal_message` struct, so they can
use the same functions for event tracing. However the model net base LP uses the `model_net_wrap_msg` struct, so it gets its own event collection function and
`st_trace_type` struct, in order to read the event type correctly from the model.
`codes_mapping_init()` was changed to register the function pointers when it is setting up the LP types. So for CODES models, you need to add a register function:
`trace_type_register(const char* name, const st_trace_type* type)` is part of the API and lets CODES know the pointers for LP initialization.
Now in the main function, you call the register function *before* calling `codes_mapping_setup()`.
```C
if (g_st_ev_trace)
svr_register_trace();
`g_st_ev_trace` is a ROSS flag for determining if event tracing is turned on.
That's all you need to add for each LP.
### Model Net LPs
In addition to the dragonfly synthetic server LP, I've already added in the necessary changes for both the model net base LP type and dragonfly (both router and terminal LPs),
so no other changes need to be made to those LPs.
For any other network LPs that are based on the model net base LP type, there are a few additional details to know.
There are two fields added to the `model_net_method` struct for pointers to the trace registration functions for each LP.
For example, right now, both the dragonfly router and terminal LPs use the same `st_trace_type dragonfly_trace_types` struct and the following function to return its pointer:
